Attach SS Sink to new Granite Countertop
Weneedhelp
AZ
I have a 22/33 overmount that I have set into my 33" Sink Cabinet.
Just had new granite top installed and would like to attach sink using a Adhesive as i had done in previous installation.
What should I use?????? which will adhere to Stainless/Granite.
Thanks, always appreciated.
Sey
If the clips that come with the sink aren't long enough to clamp it to the slab, they generally also offer longer ones as an option. The caulk helps to keep crud from accumulating under the lip, water from leaking through, and to act as a second means of holding it in place (in addition to the clamps).
Depending on the stone, some caulks can stain the stone. You may want to try it on a scrap or maybe the underside of the slab to see how yours reacts.
i think i will just call in the morning.
it gets caught at the bottom of the brass tube. 32298 grohe.
fixed
Fixed used a round file to clean instide of brass tube. thanks
Sey
