View Full Version : changing cast iron flange
neenee
10-24-2005, 07:04 AM
My toilet was wobbley so i removed it and i have a cast iron flange connected to a cast iron pipe. the flange was broken on one side and i broke the other side trying to get it lose. How can i remove it. I tried using the repair flange kit but they wouldn't tighten straight and the toilet still moved. any advice.
plumber1
10-24-2005, 07:46 AM
Whack the flange with a hammer. It will crack and you will be able to pry it off. Save the lead ring that is inside the flange right now.
You need a couple strands of oakum and means to pack the oakum and melt and pour that molten lead. Then you need a tool to pack the lead in tight.
If you decide to go that route, come back and ask, because you will get several good answers.
Gary Swart
10-24-2005, 09:39 AM
Working with cast iron pipe, oakum, and molten lead is not really a job for a DIYer. You should hire a professional for this one.
