atlantiswinterlion
- Messages
- 2
- Reaction score
- 0
- Points
- 0
Hello,
I am having a really big problem with our pressure tank. It is a galvanized ProSource pressure tank, which joins to our water line (in the basement) on a small metal line. On this line the switch box sits(ProControl, just replaced 2 wks. ago) a brand new pressure gauge, and the water line shut off valve. This valve can cut off the water to every faucet in the house if turned off. I have been searching the net far and wide to locate how to fix the horrible pressure we are suffering with. I followed the instructions to the T, yet it won't get past 10psi before dropping to 2psi. When the water is run for a shower, the pressure is pathetic to say the least, complete with surges every 7-10secs. I have replaced the switch box, the pressure gauge, the valve up top, and have used an air compressor to blow water out the open hole before putting the new gauge on. Nothing is working!! It burbles when the faucets are open an I am using the air compressor to fill it up top. The tank is not even 2 years old, and our last one served us well for 14 years. What do I do?? HELP!!
Thanks,
Jennifer
Thanks,
Jennifer
