PVC to ABS
Schipperke
Maryland
Is it OK to use a PVC Marvel Connector to a 1 1/2" ABS waste line, as well as install a 3" PVC (about 4" long to stub up) in to a ABS Closet Bend? I 'd use a PVC Closet Flange. Would use transition glue, and can this glue be used for the PVC to PVC connection (flange to stub)?
Inspectors here don't allow mixing PVC and ABS. Even with glue that is supposed to make that work somehow.
I would look for ABS fittings.
When I buy my PVC p-traps, I get the packages with ABS trap adapers.
Schipperke
Maryland
Thanks.. this will not be inspected. So the question is, in the real world is it an OK practice? Nothing is under pressure.
Are you speaking of an ABS marvel connector that has a PVC compression dealio.. I think I've seen those.
It's just not good practice to mix the two types of plastic, especially since most anything you need is available in both types of material. Now, a compression fitting between the two would work. You're not the first to say, don't worry, I'm not going to get it inspected, but consider the time when you want to sell the house...little things like this can be big red flags to an inspector, and could make selling it that much harder. AND, if a neighbor wants to be vindictive, he could call the inspector out on you and really ruin your day (and any potential savings).
Inspektor Ludwig
Journeyman/Inspector
In the good ol' UPC
I've heard of marvel rings but the only ones I've ever seen are brass soldered onto copper. I have to say I've never seen an ABS marvel, same thing I guess? My question would be why wouldn't you just use the same kind of plastic as the drain? It can't be that hard to find an ABS trap adapter.
Schipperke
Maryland
Thanks for the replies. Whether correct or not I'm not sure but have no leaks. I used a fernco fitting to the ABS waste from the PVC trap assembly for the lav. As far as inspection, no one I know is going to remove a toilet on a PVC flange and stub glued to an ABS closet bend. I pushed lots of water through it while dry fit, and no leaks.
