prepper
01-24-2011, 12:20 PM
From an earlier post I read this: "Have a helper set the thermostat up above the ambient indoor temp and you listen to the contactor. If it has 24v and does not click that is your problem."
Mine is running fine indoors and when temp is low enough the auxillary heats like normal but when temp isn't low enough inside fan just runs and runs, heat pump unit outside clicks about every 10 secs but nothing else, no running, no hum, nothing.
Know I can't troubleshoot and fix myself but any chance its just a relay or something?
Thanks
Thanks
