This is not a new subject, my standpipe started to overflow when we wash bigger loads. If the load is small I can hear the water level rising in the standpipe. I have been using the same washer for last four years without any problems. I used foam to clean the drain but it did not help. I used the 25 ft snake twice. First I inserted it quite deep but nothing came out (there was some rust on the snake and I suspect I went into the vent). Second time I could not stick it deeper than 3 ft.
I am thinking about hiring someone with the camera. One plumber suggested "flushing" the line with multi nozzle tip (does it do the trick?)
What else can I do before I hire a Pro.
Any guidance welcome
