Adjustable Floor Drains
Dlarrivee
Canada
Before I finish up and pour concrete, what is the general consensus on adjustable style floor drains (abs)?
I require a trap primer for 2 floor drains, and thought this might be a good way to plan ahead for years ahead when the flooring might change height or something along those lines...
Waste of money?
ALL the good floor drains ARE adjustable, if for no other reason than that the finished floor level could change between the time the drain is installed and the concrete is poured. In most cases, cast iron drains have the TP opening tapped into them, but ABS/PVC drains require an additonal device between them and the trap for the TP connection.
Thanks for the insight, even if I don't go with an adjustable I'll still require a drain fitting that has a hub to drill/tap for my primer to connect to...
Unfortunately the guy at the supply-house I went to on a Saturday (the only one open sat, the rest are bankers hours), looked at me like I had two heads when I asked for an adjustable abs drain.
