Shower pressure suddenly lower one day
Long Con
Oshawa, Ontario
My shower has always had pretty good pressure, but yesterday I took a shower, and the pressure was maybe half what it used to be. It was like someone was running water somewhere else in the house, but that was not the case. Same thing in today's shower.
I looked at the water meter, and there's no activity there, no water running.
What can I do to assess and fix the pressure problem?
I would check the shower head if the pressure hasn't changed anywhere else.
Some shower heads have rubber outlets that you can rub with your hand to clean. It's worth a try at least.
Some shower valves also have screen inlet filters to block any solid crud from jamming up the cartridge. Same in the showerhead. You might just remove the showerhead and check. While it is off, turn the water on to check the stream. If it is strong there, then it's in the head, if not, it's somewhere before.
Has any other work been done in the home in another location?
Careful removing the shower head and ensure you don't stress the fitting inside the wall. Wrapping the shower arm with a piece of soft rubber or canvas will protect it from getting scratched by channel locks or vice grips.
Good Luck
Sounds like the "Tile Fairy" is up to no good...
This could be the result of a small gunk of "Crap" in your mixing valve or shower head fixture.
JW
