ANY flow restrictor would be AFTER the control valve. There could be filter screens on the inlets under the chrome trim ring, which are clogged. Normally, if the flow is slow and does not increase no matter where the handle is positioned, then the problem is in the piping AFTER the handle. If it is slow for either hot or cold, but increases in the mixed/center position, then it is in the supply lines to the valve.
