View Full Version : Air Chambers
Oliver
10-13-2005, 01:21 PM
Are they any specific requirements in terms of locations for air chambers in the UPC? In a simple one family home where should they be - washing machines (cloths and dishes), WC? Where else? Are they a must.
Lakee911
10-13-2005, 05:48 PM
I think Air chambers are a no no these days. They can get all mucked up if they don't fill up over time leading to stale air and bacteria getting into your potable water. Check out this article.
http://www.builderswebsource.com/techbriefs/waterhammer.htm
Discussion on air chambers, causes of water hammer and squeal and hammer arrestors.
Jason
Vitaliy
10-13-2005, 06:56 PM
I had a very hard time to find a place where I can buy these arrestors:
http://www.**************.com/waterhammerarresters.html
But yes, they are doing the job.
- Vitaliy
finnegan
10-13-2005, 07:44 PM
I have read recommendations against air chambers as well. Same reason - stagnant water and bacteria. The mechanical water hammer arestors are supposed to work well, but you have to place them in accessable locations. Installing your pipes carefully can help reduce water hammer.
casman
10-14-2005, 08:07 AM
Well now I'm thinking I should replace all the air chambers in my home, is this really as bad as it sounds, are there any links to these studies, besides someone making claims about bacteria etc....Also I have a run of pipes that used to go to an upstairs kitchen. These were removed back to the shutoff valves. So there is about 6 feet or so of dead end pipes. Should these be removed as well?
Terry Love
10-14-2005, 09:43 AM
The main reason air chambers are a no-no, is that they water log.
If you have them in the system already, I wouldn't worry about them.
Any hardware or plumbing store should carry hammer arrestors.
I find them where they sell the copper fittings.
If you have a closed system, (check valves, PRV's) then hammer arrestors are required at all quick closing valves.
These would be
Dishwasher
Icemaker
Washer
If you're wondering about stars (***) in posts, I do block some web sites.
If you've never seen the back end stats on a board like this, you would be amazed at the number of attempts to take over and shift it into a full blown advertising medium. Sometimes 10,000 attempts per day.
Oliver
10-14-2005, 09:06 PM
Quote: If you have a closed system, (check valves, PRV's) then hammer arrestors are required at all quick closing valves"
Forgive my ignorance, what is closed system and the acronim PRV?
Since the arrestors have to be accesible what would be the most suitable location for them in an One story house (in the basement/crawl space)?
10-14-2005, 09:42 PM
A close system is a water supply system with either a check valve on it, or a pressure reducing valve.
Without these, the water can expand as much as it likes and in the process, pressure builds.
Quick closing valves are generally solenoid operated.
They are required on ALL quick closing valves.
Washer, dishwasher, icemaker.
Tub and shower valves are not considered quick closing.
An approved hammer arrestor may be hidden in walls.
We do this all the time.
It's air chambers that need accessible drains.
Oliver
10-15-2005, 07:10 AM
Thanks
And I assume that both hot and cold supplie pipes need arresters.
kordts
10-15-2005, 09:32 AM
I have found that not running any 1/2" pipe in a house will eliminate the need for air chambers. When I do work that is going to be inspected, I install them. Otherwise, the minimum pipe size I run is 3/4", with 1/2" only as risers to fixtures. Water hammer is a function of velocity. Smaller diameter=higher velocity. Larger diameter=slower velocity.
Peace out,
Kordts
Oliver
10-15-2005, 10:01 AM
That was my approach - running 3/4" pipe and only the risers being 1/2". But I am subject of inspection.
10-15-2005, 10:27 AM
And these things the inspectors like, make for a better plumbing system.
It's a homeowner benifit.
http://www.siouxchief.com/images/662334t.jpg (http://www.siouxchief.com/B_Product_Detail.cfm?GroupID=350160)
http://www.siouxchief.com/B_Products_Prods.cfm?ID=35
