My shower valve had been dripping for some time. I was surprised to get a free replacement from Delta, so I figured it was time to replace it. I had a hard time unscrewing the bonnet. I used vinegar to help loosen the crusty deposits, but I still needed channel locks to remove it. I don't think I was careful enough because a couple of times while breaking it loose, I noticed the entire housing would rotate slightly. I got the cartridge replaced and the water turned back on, only to find dripping directly behind the housing, at least I think it's called a housing. I was hoping that it was an O-ring type of seal, but now I fear that I broke a solder joint loose. Can anyone confirm or deny? Hopefully you can make out the picture, I had to keep croppong it to get it to fit the size requirement. Thank you.
