rigthis
Hello folks,
New member. Looks like a great group.
Gotta well question.
I live in Deep East Texas.
Have recently, like last week, had a new (4") well drilled and completed on my property. The driller found good sand @ between 310' and 360'.
The screen (20' long, stainless steel) was set at ~320'.
When the driller flushed / air lifted the well to purge the drill mud / dirty water / etc, he estimated the potential flow to be between 15 and 30 gpm.
The static level of the water was 70' after about 30 minutes of letting the well sit idle, but eventually it climbed up to 22' from the well head. In fact, it blew the plumbers plug off the top of the well with the air pressure built up in the casing from the water rising.... sounded like an air cannon going off.
When the submersible pump was installed, we ran it till all the 'bad' water had flushed out of the casing. Once we got down to clear water, the gpm settled at about 4 gallons per minute. I calculated this by timing how long it took to fill a 5 gallon bucket... pretty scientific huh?
We've got a 1.5 hp submersible pump and a Flex-Lite FLS120 bladderless tank.
My puzzle is this:
I let the well sit idle to allow it to recover to 'static' water level. Then I turn on the pump, and am able to maintain 12 to 16 gpm, at 10 psi (as read on the guage of my tank). This flow rate can be maintained seemingly indefinitely.
If I dump the pressure by opening all the drain valves, my flow drops to about 4.5 gpm.
I may be just missing some thing in the pressure / volume law, and if so, my instructors at Navy Dive School would be really upset. I wonder if by dumping the pressure at the tank, I'm allowing the water level in the well to drop all the way to the pump.
Any thoughts?
And sorry for the long message.
hal
My puzzle is this:
Any thoughts?
hal
