monkeygwd
I live in a small one level condo on a slab foundation. It takes several minutes to get hot water at the kitchen sink, since it is located in a peninsula, and the supply lines run through the slab. When the dishwasher runs, I always run the tap until hot. The problem is, when the dishwasher goes to refill, it fills with entirely cold water. I try to run the hot water each time I know the dishwasher is about to refill, but this wastes a lot of water, and my time. The water heater (electric) is located in the attic. I am considering either installing a hot water recirculating system, or a point of use tank type water heater, like the Bosch Ariston 4 gallon model. Neither bathroom takes a particularly long time to get hot water, so I am leaning away from the recirculation idea. Would you guys recommend I go the small tank type water heater route, or recirculate? Which would likely use less energy? Should I install a small tank type heater inline with the hot water supply?
Thanks for the opinions/suggestions.
