Faucet Connection Size
Sobershea
A review on the kitchen faucet I am interested in stated that "The water lines on this faucet are smaller than my existing faucet, so my water pressure has diminished considerably." The specifications on the faucet list a "Connection size" of 3/8" Compression. If I hadn't read the review I would have purchased the faucet, however, my water presser isn't that hot and I am concerned that the "connection size" could be an issue. Other faucets have a 1/2" connection size. So, can I blindly purchase a faucet based on looks, or do I need to take connection size into consideration?
TIA
It makes no difference. The outlet on your shutoff valve is 3/8, and the supply tubing you would be using is 3/8. A number of kitchen faucets are now coming with the option of having the 3/8 flex lines already installed directly into the faucet body.
The Feds have put limitations on the flow rate of many valves used in a home. You can easily reach that max flow with a 3/8" line. There may be some older ones still on a shelf somewhere, but even then, a 3/8" supply line is/was fairly typical.
The restriction is at the aerator, not the supply lines.
We've been using 3/8" for over fifty years.
Shower heads, kitchen faucets and bathroom faucets all have restricters in place, but not at the supply line.
Even when the faucet had 1/2" IPS inlet connections, the internal tubing was much smaller. And for years, ALL the flex lines we have used were the same ( approx 3/8) tubing, just with 1/2 or 7/16 or 3/8 ends on it.
