View Full Version : How to use two air compressors to increase CFM
cicerored
11-11-2010, 10:14 AM
Hi,
I have read that it is possible and safe to combine the output of two air compressors for high CFU applications. I was wondering how to accomplish this. It seems to me that using an unregulated air tank would be the best way. So the input of both compressors would be connected to the air tank and a 3/8" hose for the output.
Anyone ever done this or have advise?
Thanks
Red
Thatguy
11-11-2010, 11:13 AM
You likely need check valves on the compressor outputs to prevent the air from one compressor going backward into the other. Putting them in parallel increases CFM, in series increases PSI.
Using
http://en.wikipedia.org/wiki/Affinity_laws
or
http://www.google.com/cse?cx=partner-pub-3176996020956223%3Ak7qeve-w3pd&ie=ISO-8859-1&q=affinity&sa=Search
you might be able to predict the output PSI and CFM.
You'll need the "pump curve" for each compressor, the PSI vs. CFM curve.
cicerored
11-11-2010, 03:41 PM
The check valves are a great ideal. This set up would be parallel, right, with the two tanks into one?
quote; in series increases PSI.
The ONLY way to increase PSI is to adjust the pressure switch. Put check valves on the outlet of the two compressors and use short hoses to connect them into a tee. It will also work without the check valves, because both have to be set to the same pressure.
cicerored
11-11-2010, 05:43 PM
I just want to increase the CFU/Minute
Thatguy
11-11-2010, 06:27 PM
Identical compressors, right?
I don't see a difference between having two compressors running into one tank and your output is taken from that single tank
or two compressors with both their tank outputs running into a tee.
Just make sure there is no way to overpressure any tank.
Can you post the specs of the compressors? It may make a difference with positive displacement compressors vs. others.
leejosepho
11-12-2010, 05:54 AM
Either way is fine since each motor must have its own pressure switch anyway ... and both motors even could be pushing air into just one tank with their respective pressure switches sitting side-by-side on a tee (or possibly even connected to just one switch if the switch can handle the load). Also, no check valves are needed (or even a good idea) anywhere other than between each motor and its tank. Using check valves in the outputs of two tanks teed together accomplishes nothing more than making it impossible for either motor to send air into the other tank.
Edit for correction: A bleed valve and check valve likely *will* be needed for at least one tank in order to manually bleed that tank down to get that motor started at all ... and that means my thought of two pressure switches on a tee on one tank also needs some further thought!
jimbo
11-12-2010, 06:21 AM
Multi stage compressors are used for higher PSI. But as built, the guages and limit switches of "regular" compressors would not allow you to get higher PSI. I also doubt that the compressor itself would handle the much higher output, even though the DP is the same. Theory is correct,though. We used 4 stage compressors on the boats for the 4500 PSI air system.
Thatguy
11-12-2010, 08:50 AM
If both compressors are always under load you may not need a check valve. Things may get weird when the load is removed.
Most compressors have an "unloader" on their switches so that the motor can start under load. The check valves would be so that the compressors could be disconnected without having turn off both compressors and drain the pressure from them.
dlarrivee
11-13-2010, 07:50 AM
He isn't looking for pressure, he is looking for volume.
CFM is NOT PSI.
HJ is correct, almost ALL newer compressors have an unloading valve so that the motor/compressor doesn't have to fight the compression of the full tank.
