Plumbing for Laundry Sink and Washing Machine
logan
Toronto, Canada
Hi guys, wondering if you can let me know if this set up would be acceptable. I have an existing laundry tub and I wanted to add a washer box to the set up so that the washer could drain directly into the box instead of the laundry tub. I do have an existing vent directly through the roof so wondering if I need to either tie into that for the washer box or would the set up on my drawing work. I would be expanding the existing 1 1/2" pipe to the stack to a 2" pipe, but because of the placement of my hot water heater I would still have about 3 feet worth of th 1 1/2" before the stack. I know the reduction in size isn't best, but I'll have about 3 feet worth of 2" before the reducer so wondering if that will be ok.
Any comments are appreciated.
Thanks
View attachment Laundry_Washer run.zip
