Tub molding
Barry J
Mass
I had a new tub placed, and it seems like they cut the linolium floor too much, they tried to use chaulking to hold the floor in place against the tub, but it's been three months and the edge is starting to rise.
I had the floor guy come in to look, and he said that I could try a pice of quarter round painted white to solve my problem.
The problem now is that my tub base is not entirely straight. It curves towards the tub at the ends approx. 1 3/4 at both ends curves.
I looked up on line for flexible molding, I found two sites
www.flexibletrim.com
www.trimster.com
Just wanted to get suggestions or ideas
Thanks
Barry
You could try a piece of quarter round or "shoe moulding" in white plastic, which would be quite flexible. Then secure it to the floor with small/thin stainless ring-shank nails at frequent intervals.
The moulding would have to be wide enough to everlap the floor covering by enough to hold it down.
You could apply a little caulking or sealant such as white silicone between the moulding and the tub.
If the edge of the curled flooring is too hard to flatten you may have to cut it back by 1/8".
