Is there a plumbers dye?
DIYourselfer
Philippines
Trying to find a leak in bathroom. Is there a dye that the pros use that won't stain a tub? If I use a dye in the tub water then I will know when I see the dyed water on the unfinished ceiling below that it is probably the drain, not the pipes or mixing valve.
Thanks!!!
I remember many years ago, the septic field police were going around to homes and flushing a packet of dye down the toilet. Then they would walk around the property looking for the dye to break to the surface or enter a stream.
