bad ground & electricity charges?
darque
orange county california
could electricity "leak" in a home through badly ground pipes copper or other metal (?)
hypothetical~ if my copper pipes were not grounded properly causing corrosion to the water heater would that in any way use more electricity increasing the monthly kilowatt usage?
just wondering.
just wondering.
Galvanic corrosion uses DC. Your elec. meter does/should not respond to DC.
Even if it did the corrosion is caused by a DC current loop that doesn't add or subtract from your household AC usage.
But, in principle, you could test this.
No, electricty would not leak in the way that you described (i.e. on a continuous basis).
If it did you would be in danger of electrocution EVERY time you touched a faucet or metal sink. I was testing a customer's system one time with a "TicTracer" which responded to electrical currents. When I went past their refrigerator, it "lit up". The reefer housing was "live" and the only thing that prevented them from shocks was that there was no plumbing nearby that they could touch at the same time they were at the refrigerator.
