JOEG2321
10-21-2010, 08:36 AM
I currently live in a condo that is roughly 7 years old and have had nothing but problems with one of my showers. I have not had a single problem in the other bathroom whether in the sink or the shower. My particular problem is that when i turn on either the shower head or the faucet to run bathwater the water pressure is fantastic. However as I begin to make the water warmer, the pressure drops off drastically to the point where it seemingly takes forever to run a hot bath, or take a hot shower. Also worth noting is that the sink in the same bathroom as the problematic tub/shower works perfectly. I am essentially just looking for a quick fix, and or an inexpensive fix before i begin taking things apart and investigating further. Any information can help at this point.
jadnashua
10-21-2010, 11:27 AM
Keep in mind that as you first start out, you are getting cold and hot mixing; then, as you try to make it hotter, you start decreasing the amount of cold. At the warm temp, you are getting the full flow of both hot and cold supplies, but as you approach all hot, you only have the hot line. This could be a supply thing, as the hot line, especially if it has any galvanized steel pipe in it, if probably rusting, which can close off part of the flow. It may never happen, but if it does, often starts on the hot side. Do you ever get any rusty water out of the valve, especially at the start (it often clears out after a little flow to purge it)? If the valve has in-line shutoffs, the hot shutoff might not be fully opened. Or, there could be some crud lodged in the cartridge, or (if it has one) the inlet filter screen could be clogged, reducing the flow.
