chiefgunner
I'm new to a well system, here is the story. I currently have very low pressure. It started about 2 months ago. had a service call from the home warranty people and they said I needed to add salt to the softener system. It was low, but not empty, so I filled it. This did not work. I have an inline filter before the water enters the softener and I have been changing the filter way too often. Every month for the last 4 months. (NASTY brown/orange)
There is only air coming out of the air valve on top of the pressure tank. I replaced the pressure switch (My neighbor had a new one in his garage). It is a 30/50 switch. I filled the tank with air to 32psi and turned the power back on to the well pump/system.
There appears to be no water going into the pressure tank.
Where should I go from here?? Please help.
Thanks in advance.
Thanks in advance.
