Bathtub faucet leaking
Hodar
Montreal, QC
Good day,
I have noticed that at the base of the bathtub spout and the wall, there is a slow, constant leak.
Before I unscrew the spout, is there a preventive action I should take before doing this?
Tx, from Montreal
Is the leak only when the valve is turned on? If continuous, that is a problem in itself. Where is that water coming from. But when the valve is on, there still should not be a leak there, so you may need to remove the spout and find out why there is a leak there. Don't let this go, because water may be getting inside the wall.
Think of the spout as a hose...the valve is what controls the water on/off. If you notice water leaking at the wall end of the spout, your valve is leaking. Because the water is leaking out of the middle of the "hose", the hose, or spout could also be leaking. The valve might be leaking, and it's dripping down the outside of the pipe, and you notice it at the spout end, and the spout could be fine. Two different problems.
Spouts generally come in two different types: screw-on, or push-on. A typical screw-on spout doesn't have any set screw on the bottom to hold it in place. A push-on one will. That setscrew will be burried below a slot or hole, so finding it can be a pain since you can't see it, you have to feel it. To remove a spout, it might be caulked to the wall, and that can make pulling or unscrewing it really tough. A sharp blade might be able to free it, but be careful.
In many cases the water is coming out of the end of the spout, but flows back on the underside of it until it gets to the wall and then drips off. You have a faucet problem, NOT a spout problem.
