Remove a brick? Or drill holes through the brick?
Bassadict69
Benton, La
I am needing to run 2 water lines through my brick wall...should I drill through the brick? Or simply remove a brick and then seal it back up with foam or some other sealant?
Whichever I should do, what is the best way to do it?
I'd drill with a hammer drill and just make the hole as close to the OD pipe you are drilling.
Seal up the remainder with a good sealant like Sikkens or Sonnerborn sealant.
Remember you want to allow space around the pipe so that the pipe does not wear out prematurely from the vibrations caused by the water flowing through the it. Code say 2 pipe sizes larger, I would suggest at least a 1/4 inch around the pipe. I would also suggest some sort of sleeve even if it is only a couple wraps of 10 mill tape, then caulk it up with some hi quality silicone.
