gcoleman
Hello,
I just rerouted my PEX water pipes so I can finish off my basement with drywall. I ended up adding 4 new elbows, and one straight connector.
Since changing the route, the pressure is fine at the tap at 50lbs, but if I flush a toilet, then I get only about 25% water flow on any other tap. This didn't happen before I did the pipe rerouting. It used to reduce flow slightly, but not to this extent.
At first I thought it was my 10 year old water regulator, so I changed that, and still same problem.
Now I'm thinking it is all the extra elbows that is hampering the flow. I have a hard time understanding how 150 lbs pressure coming into the regulator could be impeded by elbows, but it seems to be doing it.
The picture below shows the PEX layout. The pipe used to come out of the wall on the right, go straight up towards the ceiling, and made a left turn straight across to a water regulator, and continued straight out of the room by the ceiling.
I'm thinking that the only thing that has changed is the extra four 90 elbows and the straight connector, so looking at putting back in the same configuration as before, loosing four elbows, but buried in the wall (it used to run outside the studs).
Before I put back to original config, I want to check if all those elbows could be causing the lack of flow for two taps running at the same time? Or could something else be causing it?
Any help appreciated.
Glenn
Glenn
