bsimecek
09-30-2010, 11:37 PM
Home built in the last few years... I have a copper half inch line coming out to an outside faucet (3/4 faucet). I am not going to attempt to run a new 3/4 copper (in the basement) until the spring, so i am just going to attach the system to the faucet temporarily via a pvc slip to hose thread.
The entire system is based on PVC SCH 40 (3/4 inch), and has 4 zones. I have 80 PSI coming from the faucet and about 12.5GPM. All heads are the same...Orbit Voyager 2 (3/4 connection, 3.7GPM@60PSI 2.6@30PSI)
Zones: 1=4 heads (90ft), 2=3 heads + 1/4 inch drip line (60ft), 3=3 heads + 1/4 inch drip line (130ft), 4=4 heads (80ft).
After blowing out the system for the winter via a 70PSI + 2CFM:
http://www.irrigationtutorials.com/winter.htm
http://www.ext.colostate.edu/pubs/crops/04719.html
I plan to just take the entire manifold into the garage for the winter.
I also plan on adding an AVB under each valve so to remove any vacuum issues when the valves turn on or off.
The major brass component below the faucet is a double check valve followed by a AVB (this may need to be changed over to a Pressure Vacuum Breaker
(http://www.lowes.com/pd_74193-18701-800M4-QT_0__?productId=3135141&Ntt=pressure+vacuum+breaker&pl=1¤tURL=%2Fpl__0__s%3FNtt%3Dpressure%2Bvacuum%2 Bbreaker)
When running the new copper, I plan to run 3/4 inch copper with a female fitting and a pvc male with a master shut off valve on the copper.
The entire system is on a slight grade away from the house, and I plan on building a gravel bottom box in the garden down about 12 inches from the surface level with the highest point of all the zones.
Anyone have any suggestions? I'm still learning
1151411515
1151411515
