View Full Version : Mainline Repair Still Leaks
Kiko
09-27-2010, 05:56 PM
The main line of my parents' sprinkler system was ruptured by their landscaper. It is a 1" black poly tube. I cut off the bad portion and clamped on a 1" hose connector using 2 worm gear clamps. I kept the line straight when repairing this and tightened down the clamps as much as I can, but the repair still leaks a bit. If this was on a zone, I wouldn't care, but since it is on the main line, it is always pressurized.
Do I have any other options for repairing this? I know they make compression fittings for PVC/PEX and shark fittings, but I don't think they work on the thinner walled poly pipe. Or do they? They also sell crimp-on clamps, but I didn't want to buy the expensive crimper, and not sure if those clamps will seal any better.
09-27-2010, 05:59 PM
Black Poly?
You can buy new poly, fittings and hose clamps. You just need to replace whatever is leaking.
It normally goes back together real nicely.
Kiko
09-28-2010, 09:54 AM
I repaired the bad section, but the hose clamps don't seem to be sealing the poly pipe to the hose connector.
Jerome2877
09-28-2010, 11:43 AM
There are barbed inserts made for poly pipe, are you using a regular garden hose connector? This is probably the problem.
Kiko
09-28-2010, 07:15 PM
The fitting I used was a 1" gray plastic hose connector with barbed ends.
