All appliances are working properly but my outside pipe is overflowing!!!!
zsduncan
California
Hi my name is Zlata and I think I might be in some trouble here. There is no backup or overflowing inside my home but outside there is a pipe that overflows every time I take a shower or flush the toilet.
I tried using the snake on the outside pipe but nothing came out. I got it in there about 15 feet and it came out with nothing.
I dont have a septic tank and think I am on county water system.
Please help there is waste overflowing!!!!
There is a clog, and it could be much further away than the small snake you tried. A main line usually requires a pro to clean it out. It is not normal for it to overflow outside...normally, that pipe is sealed, so unless someone left a cap of, you may have a broken pipe (which could be the clog). Time for a pro, I think. Suggest you might avoid those with 'rooter' in the name.
Thats what I was thinking. I was hoping it might be something I could fix though. Thanks for your response.
Yep You need a Plumber/Drain Cleaner to snake the line clear.
You have a clogged main sewer line.
This is not a DIY job. It will take a HD industrial sized auger to clear the drain and even if you could find one, you would literally risk your life trying to use it. These things require a trained person to use. As others noted, it is very likely the cause is a broken pipe since that is about the only way drain water would escape the drain pipe and not overflow in the house. Sorry, there's no quick, easy DIY band aid fix.
quote; As others noted, it is very likely the cause is a broken pipe since that is about the only way drain water would escape the drain pipe and not overflow in the house.
It is more likely a cleanout opening with a missing cap or plug. The reason everything inside the house is working is BECAUSE the water is escaping outdoors.
