Mckeand13 Engineer Messages 80 Reaction score 0 Points 6 Location MN Sep 23, 2010 #1 I've always seen a groove in one of the rollers on pipe cutters. What is this for? Does it have an orientation when placed on the pipe to cut (as in grooved roller on the side you're going to use)?
Mckeand13 Engineer Messages 80 Reaction score 0 Points 6 Location MN Sep 23, 2010 #2 Ah. I think i just found it. It's for accepting a flared end of tubing so you can cut the flare off. Why not just cut further down and avoid the flare?
NHmaster3015 Master Plumber Messages 833 Reaction score 2 Points 0 Location The granite state Sep 23, 2010 #3 Yes, that is exactly what it is for. Orientation wise the wheel should be centered on the mark where you wan to cut the pipe at Last edited by a moderator: Sep 2, 2020
hj Master Plumber Messages 33,613 Reaction score 1,057 Points 113 Location Cave Creek, Arizona Website www.terrylove.com Sep 23, 2010 #4 Sometimes you want to cut as little tubing as possible, so you just cut the flare off.
