I repaired one leak only to find that I had a new one. The repair was of a copper to pex transition. Apparently I did not solder the transition fitting on well, so my solution was to remove the portion of copper with the transition fitting and to use a coupling and new length of copper. To the new length of copper I attached a sharkbite fitting (3/4"). Well the sharkbite appears to have a very small leak.
I did not "prep" the copper correctly for the sharkbite. I think that I was supposed to "chamfer" the end of the copper and deburr the inner tube?
Also I was wondering if there is any kind of take off space in the sharkbite. I thought that the take offs for both sides of the fitting was 1 1/16" so I left 1/8" gap where the pipe and pex were to be joined. Was I wrong about this?
Do they sell a tool you can create a chamfer with at the big boxes? Do I need to go to a plumbing supplier instead?
Thanks
Thanks
