Does sink need to be centered over plumbing?
alexshouse
florida
We bought a house and are having it completely remodeled. We had the old 96 inch built-in vanity removed and are looking at new vanities. We found one that is 72 inches. The only problem is I don't know if we need to have sink centered over the plumbing. Thanks!
It doesn't have to be, but it's more convenient. Adding extension lines to the supply hoses is one more thing to fail. You'll take up more space under the counter with the longer trap arm, and depending on how far away it is, you may not have enough height to achieve the proper slope. But, within reason, it's doable. Each layout will be slightly different, so you'd need to know where things actually are. Also, sink depths can have a big impact (related to the slope of the drain line) - if the new sink you want is deeper and further away from the wall connection, you may not have enough slope for it to drain properly.
