View Full Version : Plastic Piece on inlet pipe
jdon88
08-21-2010, 06:47 PM
What is the purpose of the plastic piece with rubber disc inside the inlet and outlet pipes? This is on a new Bradford-White heater.
Jerome2877
08-21-2010, 07:51 PM
They are check valves to stop hot water migration through the pipes. They can cause issues as they can get build up inside them and cause flow problems. You could remove them if ya like.
Mike Monett
07-21-2011, 07:23 PM
It might be a dielectric union to prevent corrosion due to galvanic current between dissimilar metals. Check this article for more information:
"Using A Dielectric Union To Join Galvanized And Copper Water Supply Pipes"
http://www.hammerzone.com/archives/plumbing/systems/components/union_de/intro.htm
Mike Monett
jadnashua
07-22-2011, 10:54 AM
The disk means it is at a minimum, a heat trap. It may also be a dielectric union, depending on what it is made of. Make sure that they are used in the proper location (hot/cold) as if swapped, they'll tend to block flow when you turn on a valve.
