DavidTu
My main question is about the Powder WC line in that I was unable to use a 45* wye and therefore do not have an obvious way to add a CO to this run... do I even NEED a CO on this run? Please see the attached pictures. Drains are black, vents are white. This is fairly accurate depiction of the overall system I'm planning & implementing (all new), though not to scale (floor heights and major horizontal run lengths not accurate).
I am thinking of adding a 2-way CO as indicated in the pictures. Please advise... (also if I go this route do I need to use an actual 2-way CO fixture or could I use a Test-T here?) NOTE: the WC uses a 4x3 closet bend to stay within 2x8 floor joists. In order to stay in the ceiling and get around the chiimney there's a series of fittings at 'odd angles' so I do not think I can use a WYE w/ CO on this run.
If you see anything amiss anywhere please point it out to me. (The master has a false wall behind the WC allowing the diagonal run of Lav behind that wall and out of view.)
Thanks in advance.
Thanks in advance.
