monickam1
07-31-2010, 09:48 PM
Well, well. I had no idea Mr Love had an irrigation forum too :)
I had 6 Hunter spray sprinklers on one station. An installer added two more. I was concerned from the beginning that he would need to split that station into two. He didn't but should have. When I called him with pressure problems, his answer was to change the spray sprinkler heads to mp rotators (so far I am NOT impressed with these sprinkler heads) This isn't working out either. Half the time the heads don't come up all the way and the water puddles around the sprinkler head. I can touch the top of the rotators or pull up on the stem and they'll spray correctly but the answer is creating a new zone! I'm done with this guy tho. Apparently making two zones from one is a lengthy ordeal? Can someone briefly tell me what is involved? I know it's not a whole system pressure problem because the other 5 stations run perfectly at the time station 4 isn't. Also, the rotators don't rotate as fast as what I see on videos demonstrating these sprinkler heads. Again, this seems like a pressure issue.
Thanks,
Monica
Thanks,
Monica
