I'm about to change the counter/sink/etc in my kitchen and would like to install a disposer. Unfortunately, the sink that was chosen has the smaller sink on the right, and that is where we want the disposer, but the current setup has the drain going into the floor on the right side of the cabinet (then along the ceiling in the basement to the main drainpipe). I've included a diagram of what the currnet layout is (not even knowing if it is code), and was hoping if someone could provide some advice on how to setup the drain with the disposer installed on the right side.
(Red line is the floor)
There's a drop ceiling in the basement, so it is easy enough to move the drain to the left side if needed... but should the P Trap remain in the ceiling below moving forward? Should the entire setup be changed?
