edshuck
Oh, boy. Where to begin.
The tank is wall mount, the toilet is floor mount and the two "were" connected by a 2" elbow.
The brand is N O Nelson of St Louis. (they moved to someplace in Ill back in 1888 and began to concentrate on fire hydrant products.
We needed to do some work with the wall so I removed the tank. I had expected problems with the elbow so when it cracked (2" along the turn) it was no shock.
The compression fitting was frozen to the spud and to work on it I had to remove the spud. The spud washer seems to be just a ring of plumbers putty - hardened and became dust when removed.
The compression washer was packed oakum (used in cast iron soil pipe).
The spud is not the one available in the stores. There are two flanges 180 degrees apart. These fit into a slot. When inserted into the back of the bowl and turned about 160 degrees to the right - encounter a stop in the molding of the bowl. The balance of the outside of the spud is threaded and readily accepts the current lock bolt, acts as a stop for the expansion washer and accepts the expansion nut.
Question 1 - Is there anyone with N O Nelson experience that can help?
Question 2 - Is the putty thing a fix or a kludge? Or was it a washer that, over the years, just fell apart?
Any help - and as always - thanks for reading the post.
ed
ed
