View Full Version : Chicago plumbing codes regarding dmv drain pipes using PVC as of 2010
agent99
07-27-2010, 02:18 AM
Sorry if this has been answered before. I have been searching. I was under the impression that in Chicago, they only allowed for pvc in residential use, 3 stories or less, and that copper, galvanized, and cast iron had to be used above grade and only cast iron below grade for non-residential use.
I just came across a post on the web stating that pvc can now be used for ALL drain above and below grade, but cast iron still must be used under ground. Hopefully a licensed plumber can confirm this? Is this a recent code change(when?) and does it in fact apply to commercial properties?
The plumbing union has had strong clout in Chicago and has been against pvc vs other cities, mostly due to the ease of use, less cost, and loss of business, so I am surprised if this is true. I was about to pay a very steep price to replace a very long run of drain cast iron pipes that run above basement ground, so I am praying this is true!
Thanks!!!
jc60618
08-06-2010, 03:33 PM
PVC is only allowed in above ground residential applications 3 stories or less. PVC undergrounds are not allowed in Chicago.
SewerRatz
05-15-2012, 09:28 PM
Just to add to this PVC is allowed for 3 stories or less, and or three family or less buildings. So if the building is two stories but has 4 family units, PVC is then not allowed. Also PVC underground is still not allowed in Chicago.
