View Full Version : Which Cast Iron Flange Replacement is best
tomtbone
07-16-2010, 12:54 PM
Today I successfully removed the old cast iron toilet flange and am left with a 4" cast iron pipe. The top of the pipe will be about 1.25" below the level of the finished floor. I am looking at a couple of PVC/ABS replacement flange from Oatey and Sioux Chief. Which one would you guys reccomend?
Oatey Compression joint with screws to tighten compression
http://www.oatey.com/apps/catalog/instance_assets/images/catalog/productimages/cast_iron_flng_rplcmnt.jpg
Oatey Twist 'n' Set
http://www.oatey.com/apps/catalog/instance_assets/images/catalog/productimages/twist_n_set_flng.jpg
Sioux Chief Gasketed Closet Flange
http://www.siouxchief.com/Resource_/Product_Image/196//Regular/C887gam.jpg
Sioux Chief Push-Tite Flange
http://www.siouxchief.com/Resource_/Product_Image/1479//Regular/C886ga.jpg
Wally Hays
07-16-2010, 02:20 PM
They are all about the same but I like the ones with a stainless steel ring.
tomtbone
07-16-2010, 02:25 PM
Also, PVC or abs
jadnashua
07-16-2010, 02:40 PM
ABS vs PVC is irrelevant when attaching to CI, so pick the one you can get easily, or is less expensive. I'd definately go for one with the (stronger) SS ring, though. Won't rust, or deflect or break as easily as an all plastic one.
MACPLUMB 777
07-16-2010, 05:28 PM
THIS IS WHAT YOU NEED THOSE CHEAP PLASTIC FLANGES ARE JUST THAT CHEAP !
THEY ARE MADE AS REPLACEMENT FOR BAD PLASTIC FLANGES !
YOU NEED TO GO TO FRANK PATTERN & MANUFACTURING WEB SITE THEY HAVE ONE THAT IS 4" X 4"
TO BRING YOUR REPLACEMENT UP ABOVE THE FINISHED FLOOR LEVEL WHERE IT NEEDS TO BE
http://www.instantset.com/closet_rings.htm
Home
Announcements
Product Catalog
Closet Rings
Cast Iron
Model Numbers
Size
Regular
3"x2"
30
4"x2"
40
4"x2"
40TC
(w/test cap)
Instant SetŪ - Closet Ring 4"x4"
Model Numbers
Size
Regular
Deep
4"x4"
44
Instant SetŪ - Closet Ring 4"x6"
Model Numbers
Size
Regular
Deep
4"x6"
tomtbone
07-16-2010, 06:47 PM
So do those flanges fasten to the outside of the pipe then? I'm not quite getting how they work. Also, for the 2" deep size, how much pipe does there need to be to grab onto?
tomtbone
07-16-2010, 07:09 PM
07-17-2010, 06:22 AM
Any compression flange will ONLY seal if you can get the pipe smooth enough. I ONLY install cast iron flanges on cast iron pipes.
tomtbone
07-17-2010, 08:30 AM
I understand that yes. What do you do though if the cast iron pipe is more than an inch below the finished floor level? Are those blue cast iron compression flanges adjustable?
I also saw at Lowe's today that Oakey is making a cast Iron Twist and seal flange
MACPLUMB 777
07-17-2010, 10:14 AM
The blue cast iron instant set tightens on the outside of the pipe by tighting the 3 7/16 bolts
around the flange, !
That is why you get one that is 4" deep it sets down below the floor and extends up to
above flooring to make the correct fit !
MACPLUMB 777
07-17-2010, 10:17 AM
If i was doing it i would take both 4x2 and 4x4 to dry fit and make sure it tightens
correctly and will work properly ! !
Then return the one i don"t use !
jadnashua
I think what HJ was alluding to was that he only installs a new leaded ci flange on a ci pipe...they come with different depth throats to accommodate the height of the ci riser. This is the longest lasting, strongest connection, least likely to leak of all of the choices.
