View Full Version : Pipe support
jwray
09-27-2005, 05:41 AM
An amateur question, but somebody has to ask them :)
What is the preferred method (I'm OK on the spacing from my copy of the code. I need to know what material and process a real plumber would use.) for supporting and securing...
1. DWV drain lines both horizontal and vertical
2. DWV stubouts at sinks/lavs
3. Copper supply lines both horizontal and vertical
4. Copper stubouts at sinks/lavs, water closets, etc.
Thanks for helping out the novice. Just want to make sure I do it right.
Dunbar Plumbing
09-27-2005, 06:38 PM
They make PVC pipe strapping for DWV lines, also plastic J-hooks which work really well if you are close to wood structures. Stubouts are usually dry-fitted into the hubs unless the hub sits deep inside the wall. This allows for use of a desanko or other type fitting that gives you the hub to work off of instead of the piping. On copper piping they make tube talons, plastic J-hooks and copper clad drive-in J hooks. For the stubouts they make copper clad brackets that will allow you to solder them in place for stiffness. Wood can serve the same purpose as well.
jwray
09-28-2005, 05:13 AM
"Stubouts are usually dry-fitted into the hubs..."
If you dryfit the stubouts how do you do a water head test for the inspector?
I thought I needed to glue in the stubout and use a glue in test cap or the like to seal things up for the test.
Can you clarify on that?
Thanks,
Joel
Dunbar Plumbing
09-28-2005, 07:04 AM
You use a 2" fernco cap on the outside of 1.5" hub for testing. Only in the situation of the hub turning out, exposed out of the finished wall.
finnegan
09-28-2005, 07:54 AM
I guess the fernco cap would work, but I just stub out with pvc (cemented) and cap it. When it comes to to install the fixtures you just cut the caps. For copper supply lines, try to use the hangers which isolate the pipes from the framing. These are plastic and fit completely around the pipe and then have tabs or ears which attach to the framing. While there are all sorts of straps and hangers, it is always a good idea to keep a roll of plastic strapping for those add spots. When you use the strapping, don't just create a cradle between the joists on a horizontal run. You should loop the strapping around the pipe to minimize movement in all directions. You might want to use washers on drywall screws or large pan head screws to avoid the screw head pulling through the strapping.
