Rough in length
Jdon88
Pottstown PA
I measued current toilet and rough in length is 11". Will a 12" toilet fit or do I need to look for a 10" toilet? The toilet I have in mind (toto cst744el) dimensions show 3/4" between tank and wall, that is cutting it close, will the 12" fit?
Make sure that you are measuring from the wall surface (not the baseboard) to the bolts.
I believe the elongated Drake is setup for 1-1/8" spacing. That might make it assuming that your 11" measurement is accurate.
