View Full Version : Mixing valve ?'s
TonyBagadonutz
09-25-2005, 10:47 AM
Hi folks...been awhile..still working on that bath.
I have a quick question that - hopefully - someone that is familiar with Kohler products can answer for me.
We plan on installing a Kohler K T461 4V :
http://www.us.kohler.com/onlinecatalog/300x350/ccc16095.jpg
The specs state: This Memoirs Rite-Temp pressure-balancing bath and shower faucet ... , which leades me to believe that the mixing valve is included with the 461 - BUT the sheet goes on to show that other items are required: Additional Items Required and then lists a bunch of pressure-balancing valves.
To those "in-the-know"...do I need to buy a "Rite-Temp pressure-balancing valve"?
Kohler (http://www.us.kohler.com/onlinecatalog/detail.jsp?item=8406802&prod_num=T461-4V&module=Bath+%26+Shower+Faucets)
What is the difference between:
K-304-KS ~ Rite-Temp™ pressure-balancing valve with screwdriver stops (http://www.us.kohler.com/onlinecatalog/detail.jsp?item=210602&prod_num=304-KS&module=Bath+%26+Shower+Faucets&frm=)
http://www.us.kohler.com/onlinecatalog/300x350/aaa08383_wbg.jpg
and
K-304-K ~ Rite-Temp™ pressure-balancing valve w/o screwdriver stops (http://www.us.kohler.com/onlinecatalog/detail.jsp?item=210402&prod_num=304-K&module=Bath+%26+Shower+Faucets&frm=)
http://www.us.kohler.com/onlinecatalog/300x350/ccc12642.jpg
(Photo shows Rite-Temp(TM) pressure-balancing valve, less screwdriver stops.)
What are the screwdriver stops for?
Do you think I need/ don't need the stops for the bath in a SFH?
Thanks for the help! :)
sulconst2
09-25-2005, 01:19 PM
the stops are for shutting off the water to work on the valve. nice option for the money. the t461 is a trim kit. valve sold seperate. if you have 3/4" supply to the bath. get the 306-ks. it has 3/4" inlet and outlet. a bit more money but a nice option if its your own house. whatever you do dont get the memoirs toilet!
jimbo
09-25-2005, 02:28 PM
Kohler and others make a lot of their products available as separate rough-in and trim kits. One of the reasons is the builder can rough-in all the houses the same, and offer the buyer a choice of finishes and styles in the trim. It is very important to pay VERY CLOSE attention to part numbers on the catalogs so you understand exactly what you are ordering.
