Whirlpool tub used with deck mount tub filler and hand shower
five4fighting81
spencerport ny
Hello all, I am new to the Forum.
I am remodeling my bathroom and have a 2' x 6' whirlpool tub that I am installing. I would like to have a deck mount tub filler with hand wand as such:
However, I would also like to have a standard shower head mounted on the wall like in a standard shower.
How would you guys suggest I plumb this?
Any help would be appreciated.
It gets complicated, because you not only need a diverter on the tub valve to transfer water away from the spout, but then you need a three port diverter to select between the two showers. Or you can connect the tub valve to a multiport diverter and select which of the three operations you want to use. DO NOT create a system where ALL of the devices could be turned off at the same time.
That would create a "cross over" and the hot or cold could pass through the valve to the other side. You have "mixed" the water for the entire home.
