View Full Version : Help name old delta model
Antone
06-23-2010, 11:38 PM
Hi there, I'm new to the forums here and could use some help identifying this delta
tub shower model. I'm hoping to only update the trim any help is appreciated thanks.
http://i845.photobucket.com/albums/ab19/Antone206/photo.jpg
06-24-2010, 06:54 AM
Delta 1606, but usually the model number is irrelevent, as long as the screw holes are both on the bottom and it has the diverter hole. In a pinch, you could get a "diverter plug", use the regular trim ring, and then replace your spout with a diverter spout. This would probably be the way to go, especially if you are looking for anything other than chrome plated finish.
jimbo
06-24-2010, 11:24 AM
The Delta part numbers for the plate are RP7578 or RP6107 ( with colored label).
The handle is H71.
Your options to "update" that model are probably nil. You can just refresh with new parts.
