We have a Kohler k-304 shower valve and our supply pipes are 1/2 cu. The flow rate is sooo low that the valve can't be in the cold/warm temp range or else the spout diverter will release back to the spout...Are there any tricks on this valve to increase the pressure...hidden restrictors etc.? If not then we'll have to swap out the valve with the Hi Flow k-306. BUT then again will the k306 with only 1/2 cu supply still increase the flow? Thanks for your opinons. Tony
