Really bonehead move... now I need to remove PEX from a manifold
restorick
Been lurking here for a while, never posted before. Excellent info and some great folks!
Yesterday, I pulled a bonehead move. I was in the basement ceiling hooking PEX up to hot and cold manifolds when I realized I had connected one blue pipe on hot and one red pipe on cold. It was late, I was thirsty, the sun was in my eyes... whatever excuse works... lol
Anyway, any tricks on the best way to remove metal crimp connectors so that I don't damage the manifolds?
Any and all help is appreciated.
Rick
Yes you can use a very heavy duty pair of wire cutters or buy the special tool that is made
for that purpose !
OR YOU CAN GO BACK A FEW INCHES FROM THE MANIFOLD CUT THE
PEX SWITCH THEM AND SPLICE BACK WITH COUPLERS AND BE DONE
WITH THE JOB !
Using a hacksaw make a shallow cut in the crimp ring, then using a screw driver in the slot twist it until the crimp ring splits. Do not cut through the crimp ring into the pipe.
John
Water is color blind, but the person who installed blue to the cold sides and red to the hot was not. At least not until he inserted a blue line among a bunch of red ones and vice versa. It must have been real dark when that happened. You should not have to damage the manifold, but you MAY have to cut the tubing and couple a new piece to it.
HJ...
To set the record straight, the pipes were the first ones on the manifold! It was late in the day, I was craving Miller time, it was hot in the joist space, the sun was in my eyes... lol
Thanks for the tips folks - I'll do the hacksaw thing and move forward.
Thanks again!
Rick
