Sink vs Bath Tub valve question.
plantlady
michigan
H!
My husband and I found a wall mount faucet that we really love, but it made for a lavatory and not made for a bath tub. Price Pfister T49-DF1C Kenzo Collection Two Handle Wall Mount Lavatory Bathroom Faucet. We would like to mount thison the wall over a Whirlpool tub.. my question is can we use the sink faucet set and then use a bath tub valve? or is that even possible? Orwoud you suggest something else that may work. (we cant use a deck mount as this is abath remodel in an older home witha very narrow area to work with and tub has alrady been purchased.)
Thanks for the help.
plantlady
You may be able to mount it, but the flow rate on a lav. faucet is much less then a tub faucet. At 2.5 gal. a minute it would take some time to fill a whirlpool tub.
John
Yea like the hot water pouring in might turn cold before the tub fills...
Or, damn close to it...
If you were thinking of using a tub rough-in valve with those handles, you'd likely be disappointed. Plus, as noted, the flow rate would be abysmal for a tub. Some people even get annoyed filling a tub with a typical 1/2" valve designed for it, and opt to upgrade the valve to a 3/4" or even larger. A lav faucet usually has 3/8" or even smaller supply lines and internal passages; you really want at least a full 1/2" or larger, depending on the volume of the tub and your patience.
You do NOT have to mount a deck faucet above the drain. Can you make the front edge wider so a faucet could be mounted there? You would have a much better installation if you used the matching deck mounted faucets.
