replacing my bathtubs. Tub drain is threaded into the trap???
Dunebuggyjay
Central Massachusetts
Hi guys,
I just bought a house that was a foreclosure. I am in the process of replacing everything in the bathrooms. The previous owner trashed everything. And I mean everything.
So a little background on the house. It was built in 1995. The waste pipe are all black abs. It had brass gerber tub/over flow drains connected to the tubs originally.
I removed the one piece fiberglass shower/tub units. I am trying to install new acrylic tubs with alcoves in place of these fiberglass units. (there are 2 baths I am doing this to)
I purchased a new drain kit for my tubs, and went to install them today. Well after I removed the old Gerber brass units, and went to install the new gerber plastic ones, I noticed they didn't use the slip fit joint on the Trap to install the drain kit originally. It was actually threaded into a female adapter. Is this normal? What can I do to get my new drain kit (which is just made to slip into a slip fitting on the trap....which I obviously dont have)
Is there some sort of adapter I need? Or do I need to rip out the whole trap...(I hope not, as that means ripping into the ceilings down below..ughhh)
Thanks for the help!
Jay
i think he is saying he already has a fip connection how to adapt to a male to receive
tubular tail piece from a new waste & overflow assp.
