replacement toilet flange issue. Please help if you can
chriss_1
NH
Hi All.
I'm struggling with an issue I've not come across before. Removed laminate floor and found rot in flooring around area of toilet and near flange (PVC with what I believe was a cast iron ring. very rusted). In order to remove the rotted flooring, I carefully cut and pried up the ring and was going to use the Oatey 2-piece replacement ring.
The ring is a touch too big and wont properly surround the pvc lip. The OD of the pvc pipe is about 4 1/2 +/-" and the ID of the replacement flange is 5".
Any ideas/thoughts? The house was built in the 1980 and all in all quality materials were used in the building of the house.
Thanks in advance.
