davie60 New Member Messages 1 Reaction score 0 Points 0 Location scotland May 31, 2010 #1 hi i am trying to replace the element in an copper boiler i have drained the water from the tank in the loft through the hot taps but the tank still seems to be full is it safe to remove the old element any help much appreciated
MACPLUMB In the Trades Messages 1,080 Reaction score 83 Points 48 Location HOUSTON, TEXAS May 31, 2010 #2 You need to find some way to let air into the unit to finish draining the tank ! If you have some type of pop off safety valve what we call here a temp/pressure relief valve, that you can pop open or remove to allow the tank to finish draining or open the cold water taps in the house with the main cold water valve shutoff ?
