chassis
09-21-2005, 07:10 AM
This is for a toilet supply. The toilet supply valve is connected to the water supply via a close nipple and a threaded reducing bushing. The nipple has teflon tape on both ends (valve end and bushing end), and is not leaking. The bushing is threaded into a copper fitting, which in turn is sweated onto the supply piping. There is a leak at the interface between the bushing (male threads) and copper fitting (female threads). The copper fitting has a wrenching hex formed into it. The hex is slightly above the rough floor, which is concrete backerboard.
I have felt the female threads with my finger and I think a few threads are buggered. Last night I was able to stop the leaking by using pipe dope (paste) and a prodigious amount of teflon tape over the dope.
How can I make a good repair on this? Is there an equivalent of a "Helicoil" in the plumbing world? What about stem packing material? I want to avoid unsweating the hex/buggered threads fitting because I can't get access due to the CBU/plywood, which I don't want to remove because I just put the d**n stuff down. Plus the CBU is thinsetted to the plywood so it will be a ballbuster to get out.
Thanks for any advice.
