Where is this leak coming from?!?
mischke
We have water that is leaking onto the water heater. It appears to be coming from the vent that comes from the top of the water heater. The leak is so bad that at times it comes out of the joints in the vent overhead (this area is open in our house because a plumber told us the drywall was too close to the furnace pipe, so we cut the drywall away). Anyway... from this open area we can see the furnace vent, the hot water heater vent and the water pipes that come from the water heater. When we have this leak (it's intermittent) the leak appears to be coming from the vent that leads away from the water heater. Sometime the water looks rusty and sometimes cloudy or soapy. We THINK it may be related to running the dishwasher and washing machine at the same time, but hard to pin down because the leak comes about 6-8 hours after they are run together! The amount of water that leak could be measured in cups. We don't think it's condensation because of the amount. What is going on? How do we narrow this down? Please help!!
Soapy Water
i agree on the dishwasher. remove the front acess panel, and put some newspapers UNDER the machine. run a cycle and see if the rubber hose is leaking
With this kind of problem, you probably want to sort it out quickly rather than hum and haw with searching for it yourself: I would hire a plumber asap to locate and fix the problem asap...
I often reassure clients that you are not expected to know the ins and outs of things like plumbing or electrical, that's my job. That's great if it's a hobby and you're personally interested in it, but don't feel the need to know exactly what you should do in the case of an emergency (like lots of water appearing mysteriously) - dabble in this stuff when it isn't critical, and search for a plumber to call on before an emergency DOES happen so that you don't have to when it becomes serious and you're under pressure... just a little un-asked for advice :)
Wow.. I can't believe I actually agree that you should probably call a pro in on this one -- after you check the dishwasher (which will only take an hour or so). I'm a serious DIYer who has called a pro maybe once in the last 10 years.... But Kristi is right -- this could blossom into an emergency call pretty quickly.... And you know plumbers - they charge a premium late at night :eek:
lol - wow! and I can't believe that you believe that you actually agree that a pro should be called in either! good for you thezster, I'm going to have a beer now...
Kristi <-- charges mega premium if you wake her up in the middle of the night!
mistery leak
if it is in the vent of the water heater it makes me
suspicious that its probably a intermittent leak on the water
heater....from the heater itself...
how old is the unit??
before you start tearing everything apart in the house
might you consider just changeing out the heater??
if it is the dishwasher Iwould think you should be able to see
some wood that is wet above the heater
happy hunting
leak
Takes 5 min to check the dishwasher.Take the kick plate off and look underneath. If no leak there go down to the w/h and open the door where you lite the pilot and look for signs of a water leak.
Turn the thermostat way up to make the burner to come on and take a lit match or a lit piece of newspaper, blow it out and put right under the draft hood and look to see if the air flow blows away fron the flue pipe or does it suck into the flue pipe.
If it blows away then you need to check the chimney for proper draft.
A lot of humidity in the basement can cause a condisate build-up.
Thank you, everyone, for the advice. Before I posted the initial message, we had a plumber in here (I forgot to mention that). He was here for 2 hours - seemed very knowledgeable. At the time we had the hot water heater off because initially we thought the leak was from the hot water heater, because it leaks out of the bottom of the unit. We actually purchased a new hot water heater from Home Depot, but put it on hold because we realized it was coming from the vent, not the water heater itself. The water heater is 12 years old. The plumber had us run every appliance, faucet, shower, etc. and it didn't leak while he was here (of course!!). We've considered putting in the new water heater to see if it fixes the issue but are afraid of ruining it if the leak continues and leaks onto the new water heater. We are still in the process now of trying to narrow down when exactly it leaks. If we can reproduce it, we can call the plumber again.
Couple of questions from the posts
To Master Plumber Mark - We've always suspected the water heater but don't understand how the water can get from the unit into the vent?
To Toolholic - How would water from a leaking dishwasher get into the vent?
Plumber1 - Could we see condensation measured in cups? When it leaks we could probably fill a gallon bucket.
Anyway, we have a couple more things to try. I'll take the kick plate off the dishwasher and check for leaks - I'm running it right now, and we'll check the flue pipe to see if drafts probably.
Thanks!!
Update
Here is an update - I just ran the dishwasher with the kick plate off and didn't see any evidence of a leak. It's not leaking at the hot water heater either - this time. Last time I ran the dishwasher it did leak at the water heater.
This is so frustrating!!
if the leaks in the vent follow that. check the termination thru the roof. get up on the roof with a hose. have someone check from below.
when you cut the drywall away from the W. H. VENT
is there any chance a long sawsall blade cut the water heater vent and a wash machine drain pipe at the same time? i think it,s time to open up walls
